[Qgis-user] map composer: cannot set portrait
Lene Fischer
lfi at life.ku.dk
Mon Oct 28 23:25:02 PDT 2013
Hello Tim,
When you get a printcomposer, the standard is A4 - landscape. Your screencanvas is also landscape (for standard setup).
Then changing the orientation to portrait your image will change, and need to redraw the canvas and perhaps also change the scale.
I made a small video http://screencast.com/t/xE1rQrMIVEm
Hope this will answer your question.
Regards
Lene Fischer
________________________________________
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Tim Michelsen [timmichelsen at gmx-topmail.de]
Sendt: 29. oktober 2013 07:11
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] map composer: cannot set portrait
> That said, You need to change your Map item scale in the main properties
> or it's extent.
I was expecting that it gets the extend from the QGIS main window.
Obrigado.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
