[Qgis-user] map composer: cannot set portrait (extend in map	composer)
    Tim Michelsen
    timmichelsen at gmx-topmail.de
    Tue Oct 29 16:23:04 PDT 2013
>> That said, You need to change your Map item scale in the main properties
>> > or it's extent.
> I was expecting that it gets the extend from the QGIS main window.
Let's say use Natural Earth (World data set) and then I zoom to Brazil.
Below in the main window, I can then copy the extend.
What I miss is a option/button:
* "copy extend from QGIS main window" or
* a field where I could paste the copied extend string from the status
bar of the main window
Instead, the map item requries:
X-min:
Y-min
X-max:
Y-max:
Each one in an extra column
Did I overlook something? Does this functionality already exist?
Thanks a lot in advance,
Timmie
