[Qgis-user] map composer: cannot set portrait (extend in map	composer)
    Nathan Woodrow
    madmanwoo at gmail.com
    Tue Oct 29 16:27:59 PDT 2013
Hey Tim,
You can just use the set extents button.
http://i.imgur.com/4frb815.png
- Nathan
On Wed, Oct 30, 2013 at 9:23 AM, Tim Michelsen
<timmichelsen at gmx-topmail.de>wrote:
> >> That said, You need to change your Map item scale in the main properties
> >> > or it's extent.
> > I was expecting that it gets the extend from the QGIS main window.
> Let's say use Natural Earth (World data set) and then I zoom to Brazil.
> Below in the main window, I can then copy the extend.
> What I miss is a option/button:
> * "copy extend from QGIS main window" or
> * a field where I could paste the copied extend string from the status
> bar of the main window
> Instead, the map item requries:
> X-min:
> Y-min
> X-max:
> Y-max:
> Each one in an extra column
> Did I overlook something? Does this functionality already exist?
> Thanks a lot in advance,
> Timmie
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131030/47fc9fbc/attachment.html>
