[Qgis-user] Saga not working with "In processing" aka sextante
Victor Olaya
volayaf at gmail.com
Mon Sep 9 01:49:43 PDT 2013
hmmmm, let' see
can you tell me if there is any output in the log?. There should be a
test run by the saga algorithm before opening the dialog, which tries
to run the centroids algorithm on a test layer. Can you send me the
result of that test, which should be in the log (remember to enable
saga logging if it is not already enabled)
thanks!
2013/9/9 matteo <matteo.ghetta at gmail.com>:
> Hi Victor,
> sorry for bothering you again, but SAGA still doesn't work with sextante. I
> re-installed the 2.0.8 version, check the checkbox for the compatibility,
> but it always appears the windows of the missing dependencies.
> Of course I also updated qgis with the nightly repos.
> Ideas?
> Thanks
> Matteo
