[Qgis-user] Saga not working with "In processing" aka sextante
Filipe Dias
filipesdias at gmail.com
Mon Sep 9 02:10:08 PDT 2013
The current Master version on the repositories is from September 5 th. If I
remember correctly you fixed that problem on September 6th.
On Mon, Sep 9, 2013 at 9:49 AM, Victor Olaya <volayaf at gmail.com> wrote:
> hmmmm, let' see
> can you tell me if there is any output in the log?. There should be a
> test run by the saga algorithm before opening the dialog, which tries
> to run the centroids algorithm on a test layer. Can you send me the
> result of that test, which should be in the log (remember to enable
> saga logging if it is not already enabled)
> thanks!
> 2013/9/9 matteo <matteo.ghetta at gmail.com>:
> > Hi Victor,
> > sorry for bothering you again, but SAGA still doesn't work with
> sextante. I
> > re-installed the 2.0.8 version, check the checkbox for the compatibility,
> > but it always appears the windows of the missing dependencies.
> > Of course I also updated qgis with the nightly repos.
> > Ideas?
> > Thanks
> > Matteo
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130909/e7cd9aa8/attachment.html>
