[Qgis-user] Vector symbology from attribute table
Siki Zoltan siki at agt.bme.hu
Mon Aug 4 02:31:09 PDT 2014
Dear Leo,
you can do it in the properties dialog of the layer.
For example if you have a polygon layer, and the fill color is stored in
the attribute table of the layer than
1. open properties dialog of the layer
2. select style tab (left)
3. click on "Simple fill" under symbol layers (if you can't see Simple
fill, click on the triangle before Fill to extend the tree)
4. click on data defined properties... button
5. you can give an attribute or an expression of attributes to define the
fill color
I hope it helps you,
Zoltan
On Mon, 4 Aug 2014, Leo Kris Palao wrote:
> Hi QGIS users,
> Is there a way to automatically define the symbology of vector layer using
> a column in the attribute table that defines the RGB?
> I want to do this to have a uniform color coding for each land use types.
> Some land use types might have more or less classes than for each
> administrative boundary. I am thinking if I can encode the RGB values in my
> attribute table and later use it to define my symbology.
> Thanks for any help and advice,
> -Leo
