[Qgis-user] Vector symbology from attribute table
Leo Kris Palao lk.palao at gmail.com
Mon Aug 4 19:54:58 PDT 2014
Hi Zoltan,
I tried it and it was working, it defines well the symbology of my vector
layer. However, there is a little bit of problem. In my legend items it
only create one color (black). the color scheme of my legend doesn't seem
to follow the color combinations that I set in my attribute table. it would
be better if the color scheme of my attribute table will be reflected also
in my legend items.
This is how I encoded the color codes in my attribute table:
class                                  color (R, G, B)
1                                         197, 197, 197
Thanks,
-Leo
On Mon, Aug 4, 2014 at 5:31 PM, Siki Zoltan <siki at agt.bme.hu> wrote:
> Dear Leo,
> you can do it in the properties dialog of the layer.
> For example if you have a polygon layer, and the fill color is stored in
> the attribute table of the layer than
> 1. open properties dialog of the layer
> 2. select style tab (left)
> 3. click on "Simple fill" under symbol layers (if you can't see Simple
> fill, click on the triangle before Fill to extend the tree)
> 4. click on data defined properties... button
> 5. you can give an attribute or an expression of attributes to define the
> fill color
> I hope it helps you,
> Zoltan
> On Mon, 4 Aug 2014, Leo Kris Palao wrote:
>  Hi QGIS users,
>> Is there a way to automatically define the symbology of vector layer using
>> a column in the attribute table that defines the RGB?
>> I want to do this to have a uniform color coding for each land use types.
>> Some land use types might have more or less classes than for each
>> administrative boundary. I am thinking if I can encode the RGB values in
>> my
>> attribute table and later use it to define my symbology.
>> Thanks for any help and advice,
>> -Leo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140805/2491b29d/attachment.html>
