[Qgis-user] CRS-problem
Andre Joost andre+joost at nurfuerspam.de
Mon Aug 4 08:10:54 PDT 2014
Am 04.08.2014 11:09, schrieb Hakala Oiva (MTT):
> Hi
> My decimal problem disappeared when I removed Qgis (sudo apt-get
> --purge remove) and reinstalled it.
> But a new "problem" appeared. When I open those old field data (as in
> the zip file I sent to Werner), the CRS was OK (EPSG:2392) in Qgis
> before. Now when I open the same data, Qgis says USER:100000 as a
> CRS.
Can you select EPSG:2392 manually with "Set CRS for Layer", or is it
missing?
Does it help if you delete the .qpj file?
HTH,
André Joost
