[Qgis-user] CRS-problem
Hakala Oiva (MTT)
oiva.hakala at mtt.fi
Mon Aug 4 23:06:04 PDT 2014
Yes I can manually select 2392. I think the problem is, that Qgis still says USER:100000 on the right corner. I think the problem is, that project crs won't change, as it does in my private laptop at home. Project crs will change only IF .qpj file is present. But I have a lot of old data in 2392 with no qpj-files.
Oiva
Can you select EPSG:2392 manually with "Set CRS for Layer", or is it
missing?
Does it help if you delete the .qpj file?
HTH,
André Joost
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
