[Qgis-user] CRS-problem
Hakala Oiva (MTT)
oiva.hakala at mtt.fi
Tue Aug 5 22:49:08 PDT 2014
Hello
Happy end. The solution was (for me) to use Synaptic and unistall all the Qgis-dependent packages with their settings, then run apt-get autoremove, boot computer, and reinstall Qgis. Now everything works as expected.
Oiva
________________________________________
Lähettäjä: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] käyttäjän Hakala Oiva (MTT) [oiva.hakala at mtt.fi] puolesta
Lähetetty: 5. elokuuta 2014 9:06
Vastaanottaja: Andre Joost; qgis-user at lists.osgeo.org
Aihe: Re: [Qgis-user] CRS-problem
Yes I can manually select 2392. I think the problem is, that Qgis still says USER:100000 on the right corner. I think the problem is, that project crs won't change, as it does in my private laptop at home. Project crs will change only IF .qpj file is present. But I have a lot of old data in 2392 with no qpj-files.
Oiva
Can you select EPSG:2392 manually with "Set CRS for Layer", or is it
missing?
Does it help if you delete the .qpj file?
HTH,
André Joost
