[Qgis-user] two problems
Tomas Lanczos tlanczos at gmail.com
Fri Aug 8 07:38:37 PDT 2014
Sorry, I forgot to mention - the "import sip" command within the python2
interpreter went without error messages.
On Fri, Aug 8, 2014 at 1:02 PM, Tomas Lanczos <tlanczos at gmail.com> wrote:
> Thank You for Your quick answer Donovan,
> tha grass error was solved,
> the installation proceed wtithout any problem after removing the
> #    -DWITH_MAPSERVER=TRUE \
> line from the PKGBUILD script. I really don't know what was wrong with it
> the sip error remains. Do You think that it should help reinstall the sip?
> Tomas
> On Thu, Aug 7, 2014 at 1:17 AM, Donovan Cameron <sault.don at gmail.com>
> wrote:
>>  I've noticed some users reporting that error too.
>> But I use a custom build of grass 6 which I've uploaded to my dropbox[1]
>> - can you give it a try?
>> I can't figure out why QGIS has trouble finding that folder during
>> configuration.
>> As for the sip error... One of the QGIS dependencies is python2-sip so it
>> should be able to import the sip module when it starts.
>> Are you able to run...
>> % python2
>> >>> import sip
>> ...without errors?
>> Donovan
>> [1] https://db.tt/ClXi7MsC
>> On 06/08/14 03:44 PM, Tomas Lanczos wrote:
>> Hello everybody.
>>  I'd like to install qgis 2.4 on my Manjaro box, using the AUR (Arch
>> linux) repository - https://aur.archlinux.org/packages/qgis/
>> In fact, it is a compilation process, with a source cod downloaded from
>> git://github.com/qgis/QGIS.git#branch=release-2_4
>>  PROBLEM NO. 1
>>  if I compile it without grass support, the compilation/installation
>> process is going out without problem, but after starting qgis, I got the
>> following error message:
>>  ouldn't load SIP module.
>> Python support will be disabled.
>>  Traceback (most recent call last):
>>   File "", line 1, in
>> ImportError: No module named sip
>>  Python version:
>> 2.7.8 (default, Jul  1 2014, 17:30:21)
>> [GCC 4.9.0 20140604 (prerelease)]
>>  QGIS version:
>> 2.4.0-Chugiak 'Chugiak', ed14cf3
>>  Python path:
>> ['/usr/share/qgis/python', u'/home/tomas/.qgis2/python',
>> u'/home/tomas/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
>> '/home/tomas', '/usr/share/qgis/python', '/usr/local/lib/python27.zip',
>> '/usr/local/lib/python2.7', '/usr/local/lib/python2.7/plat-linux2',
>> '/usr/local/lib/python2.7/lib-tk', '/usr/local/lib/python2.7/lib-old',
>> '/usr/local/lib/python2.7/lib-dynload',
>> '/usr/local/lib/python2.7/site-packages']
>>  PROBLEM No.2
>>  It is essential for me to use qgis with grass support, so I tried to
>> compile qgis with the following options:
>>   cmake ../ \
>>     -DCMAKE_BUILD_TYPE=Release \
>>     -DCMAKE_SKIP_RPATH=ON \
>>     -DCMAKE_INSTALL_PREFIX=/usr \
>>     -DENABLE_TESTS=OFF \
>>     -DQGIS_MANUAL_SUBDIR=share/man \
>>     -DPYTHON_EXECUTABLE=/usr/bin/python2 \
>>     -DPYTHON_LIBRARY=/usr/lib/libpython2.7.so \
>>     -DPYTHON_INCLUDE_PATH=/usr/include/python2.7 \
>>     -DPYTHON_SITE_PACKAGES_DIR=/usr/lib/python2.7/site-packages \
>>     -DQT_QMAKE_EXECUTABLE=/usr/bin/qmake-qt4 \
>>     -DWITH_INTERNAL_QWTPOLAR=OFF \
>>     -DWITH_INTERNAL_SPATIALITE=OFF \
>>     -DGRASS_PREFIX=/opt/grass64 \
>> #    -DWITH_GLOBE=TRUE \
>>  In this case I'm getting this errormessage after the configuring
>> process:
>>  -- Configuring done
>> -- Generating done
>> -- Build files have been written to:
>> /home/tomas/builds/qgis/src/qgis/build
>> /home/tomas/builds/qgis/PKGBUILD: line 98: -DGRASS_PREFIX=/opt/grass64:
>> No such file or directory
>> ==> ERROR: A failure occurred in build().
>>     Aborting...
>>  The strange thing is that, the "/opt/grass64" directory is existing,
>> but it can't locate it.
>>  Many thanks in advance for any feedback
>>  Tomas
>> Water, taken in moderation cannot hurt anybody.
>>         -- Mark Twain
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>         -- Mark Twain
        -- Mark Twain
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140808/862dc0f2/attachment.html>
