[Qgis-user] Problem with VRT format
Patrick Giraudoux
patrick.giraudoux at univ-fcomte.fr
Mon Aug 11 05:23:00 PDT 2014
Le 11/08/2014 14:12, Even Rouault a écrit :
> Selon Patrick Giraudoux <patrick.giraudoux at univ-fcomte.fr>:
>> Dear lister,
>> I meet a problem trying to wrap layers 10, 20, 30, 40, 50, 70 of
>> landstat ETM into a VRT format. Everything goes well including writing
>> the VRT file via the raster menu (see the result below), BUT when I load
>> it from QGIS and try to find the layers in the "properties" (mutiple
>> band colors), I can just access to "band1 (grey)"...
>> I am working with QGIS 2.2.0 Valmiera under Windows 7 pro.
>> Any idea about what happens ?
> Patrick,
> Yes, you have combined the files with the (default) option that is used to
> create mosaics. Which you do not want since they have the same extent, but you
> would want to make a band with each one of them. I have no QGIS at hand right
> now, but the gdalbuildvrt utility that QGIS likely uses has a -separate option
> to do what you want. Perhaps the QGIS GUI has also a "separate" checkbox for
> that. Otherwise time to go on the command line and try
> http://gdal.org/gdalbuildvrt.html
> Even
Indeed... I came back to the black board on the VRT xml description
file... all the "band" files were collapsed within one band
<VRTRasterBand dataType="Byte" band="1">
<SimpleSource>
</SimpleSource>
<SimpleSource>
</SimpleSource>
</VRTRasterBand>
Instead of :
<SimpleSource>
</SimpleSource>
</VRTRasterBand>
<VRTRasterBand dataType="Byte" band="2">
<SimpleSource>
</SimpleSource>
</VRTRasterBand>
I changed it "by hand" (quite boring...) and it works well now.
There is a -separate option, indeed in QGIS Valmiera. I will try it.
Thanks and best,
Patrick
