[Qgis-user] Map setting
Stefan Kiefer st_kiefer at web.de
Tue Aug 12 01:12:54 PDT 2014
Hi Azizul,
what exactly do you mean with vertical. Is North to the left or right, or Do you
want to rotate the original directions?
Maybe you use odd projection settings...
> "Md.Azizul Haque" <haque.azizul320 at yahoo.com> hat am 12. August 2014 um 09:58
> geschrieben:
> Hi All,
> I see the map in my screen in the vertical position . I need it to set at
> horizontal . Appreciated for your suggestion.
> In addition I also add some bar graph using add diagram . However I could not
> able to mention name for each bar for each field.
> Please guide me.
> Regards
> Azizul
> Sent from my iPhone
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140812/7893860e/attachment.html>
