[Qgis-user] Map setting
Richard B. Sennoga
richsenoga at me.com
Tue Aug 12 01:40:46 PDT 2014
Hi Azizul
Did you want to mean that the paper orientation was set to portrait and you preferred it to appear in landscape format? If so, you'll need to check the properties and make the adjustments as appropriate.
Hope this helps!
Rchd.
Sent from my iPhone
> On Aug 12, 2014, at 11:12 AM, Stefan Kiefer <st_kiefer at web.de> wrote:
> Hi Azizul,
> what exactly do you mean with vertical. Is North to the left or right, or Do you want to rotate the original directions?
> Maybe you use odd projection settings...
> > "Md.Azizul Haque" <haque.azizul320 at yahoo.com> hat am 12. August 2014 um 09:58 geschrieben:
> > Hi All,
> > I see the map in my screen in the vertical position . I need it to set at horizontal . Appreciated for your suggestion.
> > In addition I also add some bar graph using add diagram . However I could not able to mention name for each bar for each field.
> > Please guide me.
> > Regards
> > Azizul
> > Sent from my iPhone
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
