[Qgis-user] R: spatial interpolation by a shape file of points
Carlos Cerdán
sig.upagu at gmail.com
Tue Aug 12 07:12:23 PDT 2014
Hi Tonino
I think this is related to how QGIS takes "null" values in this version:
null values are taken as "minus infinite" (-inf), then perhaps it is also
taken as "nan" (not a number).
Try to make your work with GRASS plugin. If you are not familiar with it,
try to convert "nan" values into zero values. Try this expression with
raster calculator:
(DEM<0)*0+(DEM>=0)
This expression converts values less than zero to 0. If you have layers
with different extension, you must be aware about it en raster calc.
Good luck
Carlos Cerdán
2014-08-12 8:34 GMT-05:00 CONTI Tonino <t.conti at comune.jesi.an.it>:
> Hi Luis Miguel,
> I tried to reduce points and lower the resolution without resolve.
> I thought then that it was a problem with the type of data contained in
> the field that expresses the elevation.
> I then tried to use a number of type double with an accuracy of one
> decimal but I have not solved yet.
> Tonino
> *Da:* Luis Miguel Royo Pérez [luis.miguel.royo at gmail.com]
> *Inviato:* martedì 12 agosto 2014 11.18
> *A:* qgis-user at lists.osgeo.org
> *Oggetto:* Re: [Qgis-user] spatial interpolation by a shape file of points
> Hello,
> maybe I'm wrong, but when I have that message in any software is something
> related with RAM. Maybe the raster file created is very large, try to make
> one with low resolution.
> Best wishes.
> El 12/08/14 a las #4, CONTI Tonino escribió:
> ing a dem from a point file format in shape.
> The raster is not shown but qgis returns the message "bad allocation" and
> the legend shows "nan".
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140812/5cb5df3d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140812/5cb5df3d/attachment.png>
