[Qgis-user] Question regarding point to grid analysis
Carlos Cerdán
sig.upagu at gmail.com
Tue Aug 12 12:31:56 PDT 2014
Hi Mark:
I think that "point sampling tool" plugin is the tool what you need, With
it, you take the corresponding raster value into the points attribute
table, so in a new column you can calculate difference between point value
and sampled value and make a statistic analysis of that difference.
Good luck
Carlos Cerdán
2014-08-12 13:35 GMT-05:00 Mark Coletti <mcoletti at gmail.com>:
> I have two sets of vaguely coincident point data that I'd like to compare.
> Each point has a corresponding measure, and I'd like to assess the spatial
> similarity between these two sets of measurements. My approach would be to
> convert these values into grid data and then use techniques for comparing
> the similarity of matrices.
> Since I'm new to using qgis in an analytical fashion I'm uncertain of the
> best way of implementing this scheme. For one thing, there appear to be a
> number of different means of converting point data into
> grids/matrices/raster data -- e.g., heatmaps or grid interpolation-- and I
> have the additional constraints of ensuring that the corresponding MBRs and
> grid cell sizes are identical for fair comparison.
> What would be the best way to do this in qgis? (And, alas, I'm not
> entirely sure by what I mean by "best". Easiest to do? Less error prone?)
> Cheers!
> Mark
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140812/2b361fd4/attachment.html>
