[Qgis-user] two problems
Tomas Lanczos tlanczos at gmail.com
Tue Aug 12 14:42:07 PDT 2014
Hello Don,
I installed the sip for python3 and python2 as well. The qgis is installed
against python2, as it is clen also from the configure options (see my
first post in this thread). When I start the qgis within a terminal, the
olny message I get is the following:
(qgis:21601): Gtk-WARNING **: Unable to locate theme engine in module_path:
"thinice",
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_US]
Warning: QGraphicsScene::addItem: item has already been added to this scene
Regards
Tomas
On Fri, Aug 8, 2014 at 6:53 PM, Saulteau Don <sault.don at gmail.com> wrote:
> That sip error has me stumped, the only thing I could guess is that
> for some reason QGIS compiled against python3 and maybe sip for
> python3 is not installed.
> It should of built against python2.
> Do you get anything that looks useful in an strace when starting QGIS
> from the command line? I'd recommend looking at that, though I'm not
> personally the best at reading those things, but sometimes something
> does stand out.
> Donovan
> On Fri, Aug 8, 2014 at 6:38 AM, Tomas Lanczos <tlanczos at gmail.com> wrote:
> > Sorry, I forgot to mention - the "import sip" command within the python2
> > interpreter went without error messages.
> > On Fri, Aug 8, 2014 at 1:02 PM, Tomas Lanczos <tlanczos at gmail.com>
> wrote:
> >> Thank You for Your quick answer Donovan,
> >> tha grass error was solved,
> >> the installation proceed wtithout any problem after removing the
> >> #    -DWITH_MAPSERVER=TRUE \
> >> line from the PKGBUILD script. I really don't know what was wrong with
> it
> >> the sip error remains. Do You think that it should help reinstall the
> sip?
> >> Tomas
> >> On Thu, Aug 7, 2014 at 1:17 AM, Donovan Cameron <sault.don at gmail.com>
> >> wrote:
> >>> I've noticed some users reporting that error too.
> >>> But I use a custom build of grass 6 which I've uploaded to my
> dropbox[1]
> >>> - can you give it a try?
> >>> I can't figure out why QGIS has trouble finding that folder during
> >>> configuration.
> >>> As for the sip error... One of the QGIS dependencies is python2-sip so
> it
> >>> should be able to import the sip module when it starts.
> >>> Are you able to run...
> >>> % python2
> >>> >>> import sip
> >>> ...without errors?
> >>> Donovan
> >>> [1] https://db.tt/ClXi7MsC
> >>> On 06/08/14 03:44 PM, Tomas Lanczos wrote:
> >>> Hello everybody.
> >>> I'd like to install qgis 2.4 on my Manjaro box, using the AUR (Arch
> >>> linux) repository - https://aur.archlinux.org/packages/qgis/
> >>> In fact, it is a compilation process, with a source cod downloaded from
> >>> git://github.com/qgis/QGIS.git#branch=release-2_4
> >>> PROBLEM NO. 1
> >>> if I compile it without grass support, the compilation/installation
> >>> process is going out without problem, but after starting qgis, I got
> the
> >>> following error message:
> >>> ouldn't load SIP module.
> >>> Python support will be disabled.
> >>> Traceback (most recent call last):
> >>>   File "", line 1, in
> >>> ImportError: No module named sip
> >>> Python version:
> >>> 2.7.8 (default, Jul  1 2014, 17:30:21)
> >>> [GCC 4.9.0 20140604 (prerelease)]
> >>> QGIS version:
> >>> 2.4.0-Chugiak 'Chugiak', ed14cf3
> >>> Python path:
> >>> ['/usr/share/qgis/python', u'/home/tomas/.qgis2/python',
> >>> u'/home/tomas/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
> >>> '/home/tomas', '/usr/share/qgis/python', '/usr/local/lib/python27.zip',
> >>> '/usr/local/lib/python2.7', '/usr/local/lib/python2.7/plat-linux2',
> >>> '/usr/local/lib/python2.7/lib-tk', '/usr/local/lib/python2.7/lib-old',
> >>> '/usr/local/lib/python2.7/lib-dynload',
> >>> '/usr/local/lib/python2.7/site-packages']
> >>> PROBLEM No.2
> >>> It is essential for me to use qgis with grass support, so I tried to
> >>> compile qgis with the following options:
> >>>  cmake ../ \
> >>>     -DCMAKE_BUILD_TYPE=Release \
> >>>     -DCMAKE_SKIP_RPATH=ON \
> >>>     -DCMAKE_INSTALL_PREFIX=/usr \
> >>>     -DENABLE_TESTS=OFF \
> >>>     -DQGIS_MANUAL_SUBDIR=share/man \
> >>>     -DPYTHON_EXECUTABLE=/usr/bin/python2 \
> >>>     -DPYTHON_LIBRARY=/usr/lib/libpython2.7.so \
> >>>     -DPYTHON_INCLUDE_PATH=/usr/include/python2.7 \
> >>>     -DPYTHON_SITE_PACKAGES_DIR=/usr/lib/python2.7/site-packages \
> >>>     -DQT_QMAKE_EXECUTABLE=/usr/bin/qmake-qt4 \
> >>>     -DWITH_INTERNAL_QWTPOLAR=OFF \
> >>>     -DWITH_INTERNAL_SPATIALITE=OFF \
> >>>     -DGRASS_PREFIX=/opt/grass64 \
> >>> #    -DWITH_GLOBE=TRUE \
> >>> In this case I'm getting this errormessage after the configuring
> process:
> >>> -- Configuring done
> >>> -- Generating done
> >>> -- Build files have been written to:
> >>> /home/tomas/builds/qgis/src/qgis/build
> >>> /home/tomas/builds/qgis/PKGBUILD: line 98: -DGRASS_PREFIX=/opt/grass64:
> >>> No such file or directory
> >>> ==> ERROR: A failure occurred in build().
> >>>     Aborting...
> >>> The strange thing is that, the "/opt/grass64" directory is existing,
> but
> >>> it can't locate it.
> >>> Many thanks in advance for any feedback
> >>> Tomas
> >>> Water, taken in moderation cannot hurt anybody.
> >>>         -- Mark Twain
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>         -- Mark Twain
> >         -- Mark Twain
        -- Mark Twain
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140812/eca7af4f/attachment.html>
