[Qgis-user] Plugin Announcement: Sync Composer with Map
boesiii
boesiii at yahoo.com
Wed Aug 13 10:06:19 PDT 2014
I am pleased to announce my Plugin, Sync Composer with Map. The plugin
synchronizes the map canvas extents and scale with a map found in Composer.
It has similar functionality equal to a button (Set to map canvas extent)
found in the Item Properties of a map object in Composer but it easier to
find and requires less clicks. The plugin can be activated using the menu
(Plugins -> Sync Composer with Map) or the plugin toolbar button.
I wrote the plugin because I needed as easier procedure to update the
Composer map object so that it was the same view from the Map Canvas.
The plugin will works if you have one map or multiple maps in Composer. If
you have multiple maps in Composer and would like to synchronize a specific
map, select the map to be synchronized and activate the plugin and it will
synchronize the selected map.
Hope you find it useful!
Ed B
http://plugins.qgis.org/plugins/syncComposerWithMap/
View this message in context: http://osgeo-org.1560.x6.nabble.com/Plugin-Announcement-Sync-Composer-with-Map-tp5156213.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
