[Qgis-user] Freehand editing
Bernhard Ströbl bernhard.stroebl at jena.de
Wed Aug 13 22:55:14 PDT 2014
Hi Carlos,
I do not know freehandEditing but I ran into the same (?) problem with
digitizingTools [1]. It was an issue in QGIS 2.4 [2]. You may check if
the problem persists in current master.
Bernhard
[1] http://hub.qgis.org/issues/10857
[2] http://hub.qgis.org/issues/10865
Am 13.08.2014 16:30, schrieb Carlos Cerdán:
> Hi list:
> I  have an issue with "freehand editing" plugin.
> Using it, I can freehand digitize a new polygon and when i finish it,
> pops up an attribute windows that it's intended to fill with respective
> values, but it has all fields gray color and "accept" button
> deactivated, just "cancel" is activated.
> I've activated (and deactivated) topological editing and it doesn't work
> in QGIS 2.4 - Ubuntu 14.04, but works fine in QGIS 2.2 - Windows 7.
> It's a linux bug? Do I need some extra packet?. If it's a bug, Is there
> an alternative to this plugin? (It's too hard digitizing by doing click
> - click - click in every vertex).
> Regards
> Carlos Cerdan
__________ Information from ESET Mail Security, version of virus signature database 10252 (20140814) __________
The message was checked by ESET Mail Security.
http://www.eset.com
