[Qgis-user] Freehand editing
Carlos Cerdán sig.upagu at gmail.com
Wed Aug 13 12:35:24 PDT 2014
Yes it is! Thak you very much Andrew, now it works well but attributes has
to be in a separated step.
Regards
Carlos
2014-08-13 13:54 GMT-05:00 Andrew <amcaninch at gmail.com>:
> Hi Carlos,
> I ran into this problem yesterday in 2.4(i dont remember if i was
> working in windows or linux) and I was able to get around it by
> suppressing the pop-up window (settings>options>digitizing and check
> the box to suppress the pop-up attribute window).
> Hope that helps,
> Andrew
> On Wed, Aug 13, 2014 at 7:30 AM, Carlos Cerdán <sig.upagu at gmail.com>
> wrote:
> > Hi list:
> > I  have an issue with "freehand editing" plugin.
> > Using it, I can freehand digitize a new polygon and when i finish it,
> pops
> > up an attribute windows that it's intended to fill with respective
> values,
> > but it has all fields gray color and "accept" button deactivated, just
> > "cancel" is activated.
> > I've activated (and deactivated) topological editing and it doesn't work
> in
> > QGIS 2.4 - Ubuntu 14.04, but works fine in QGIS 2.2 - Windows 7.
> > It's a linux bug? Do I need some extra packet?. If it's a bug, Is there
> an
> > alternative to this plugin? (It's too hard digitizing by doing click -
> click
> > - click in every vertex).
> > Regards
> > Carlos Cerdan
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140813/f28495e8/attachment.html>
