[Qgis-user] Freehand editing
Andrew amcaninch at gmail.com
Wed Aug 13 11:54:47 PDT 2014
Hi Carlos,
I ran into this problem yesterday in 2.4(i dont remember if i was
working in windows or linux) and I was able to get around it by
suppressing the pop-up window (settings>options>digitizing and check
the box to suppress the pop-up attribute window).
Hope that helps,
Andrew
On Wed, Aug 13, 2014 at 7:30 AM, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> Hi list:
> I  have an issue with "freehand editing" plugin.
> Using it, I can freehand digitize a new polygon and when i finish it, pops
> up an attribute windows that it's intended to fill with respective values,
> but it has all fields gray color and "accept" button deactivated, just
> "cancel" is activated.
> I've activated (and deactivated) topological editing and it doesn't work in
> QGIS 2.4 - Ubuntu 14.04, but works fine in QGIS 2.2 - Windows 7.
> It's a linux bug? Do I need some extra packet?. If it's a bug, Is there an
> alternative to this plugin? (It's too hard digitizing by doing click - click
> - click in every vertex).
> Regards
> Carlos Cerdan
> Qgis-user mailing list
