[Qgis-user] Freehand editing
Carlos Cerdán
sig.upagu at gmail.com
Wed Aug 13 12:38:54 PDT 2014
Thank you very much Richard, I've created a ticket... now updated by
Andrew.
Regards
Carlos
2014-08-13 12:33 GMT-05:00 Richard Duivenvoorde <rdmailings at duif.net>:
> Hi Carlos,
> I tried both in current master en on 2.4 en on 2.2 version on Debian
> here, and actually none is working indeed.
> Not sure if it is working on Windows for those version...
> From
> http://plugins.qgis.org/plugins/freehandEditing/
> I found that you can create issues with the plugin here:
> http://hub.qgis.org/projects/freehandediting/issues
> please do issue your problems there.
> Regards,
> On 13-08-14 16:30, Carlos Cerdán wrote:
> > Hi list:
> > I have an issue with "freehand editing" plugin.
> > Using it, I can freehand digitize a new polygon and when i finish it,
> > pops up an attribute windows that it's intended to fill with respective
> > values, but it has all fields gray color and "accept" button
> > deactivated, just "cancel" is activated.
> > I've activated (and deactivated) topological editing and it doesn't work
> > in QGIS 2.4 - Ubuntu 14.04, but works fine in QGIS 2.2 - Windows 7.
> > It's a linux bug? Do I need some extra packet?. If it's a bug, Is there
> > an alternative to this plugin? (It's too hard digitizing by doing click
> > - click - click in every vertex).
> > Regards
> > Carlos Cerdan
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140813/fc8b9548/attachment.html>
