[Qgis-user] Freehand editing
Richard Duivenvoorde rdmailings at duif.net
Wed Aug 13 10:33:01 PDT 2014
Hi Carlos,
I tried both in current master en on 2.4 en on 2.2 version on Debian
here, and actually none is working indeed.
Not sure if it is working on Windows for those version...
From
http://plugins.qgis.org/plugins/freehandEditing/
I found that you can create issues with the plugin here:
http://hub.qgis.org/projects/freehandediting/issues
please do issue your problems there.
Regards,
On 13-08-14 16:30, Carlos Cerdán wrote:
> Hi list:
> I  have an issue with "freehand editing" plugin.
> Using it, I can freehand digitize a new polygon and when i finish it,
> pops up an attribute windows that it's intended to fill with respective
> values, but it has all fields gray color and "accept" button
> deactivated, just "cancel" is activated.
> I've activated (and deactivated) topological editing and it doesn't work
> in QGIS 2.4 - Ubuntu 14.04, but works fine in QGIS 2.2 - Windows 7.
> It's a linux bug? Do I need some extra packet?. If it's a bug, Is there
> an alternative to this plugin? (It's too hard digitizing by doing click
> - click - click in every vertex).
> Regards
> Carlos Cerdan
> Qgis-user mailing list
