[Qgis-user] Velocity Difference Calculation?
Randal Hale
rjhale at northrivergeographic.com
Sun Aug 17 15:22:41 PDT 2014
I can think of a couple of ways you might be able to do this - but
considering I haven't done something like this before it's a guess.
You can derive an interval in seconds I believe (referencing
http://nathanw.net/2012/06/30/better-date-and-time-support-in-qgis-expressions-and-styles/)
from the point data - I'm assuming you have date and time (or at least
time).
You could connect the points with a line (that would give you distance).
I'm thinking this might be better accomplished in a database as opposed
to a shapefile (assuming shapefile).
...and I think I've just given you the most abstract assumed non-answer
ever.
Lemme think on this one a bit more. Hopefully someone has a practical
answer.
Randy
On 08/17/2014 05:57 PM, dean.walker151 at gmail.com wrote:
> Hi all,
> I’m working on some point data that has been collected using a combine
> in an agricultural field. Trying to figure out a way to compare speed
> between the dropped points? I’m not sure how to start….can anyone help?
> Thanks
> Dean
> Sent from Windows Mail
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140817/1c06ee54/attachment.html>
