[Qgis-user] Velocity Difference Calculation?
dean.walker151 at gmail.com
Sun Aug 17 15:34:12 PDT 2014
Yeah, I’ve got a distance reference that covers the amount of distance covered in the time from the last point. I’m just missing the way to actually do the calculation in the program. I cant see a way to compare a point to the one before it.
Thanks!
Dean
Sent from Windows Mail
Sent: Sunday, August 17, 2014 3:22 PM
To: dean.walker151 at gmail.com, qgis-user at lists.osgeo.org
I can think of a couple of ways you might be able to do this - but considering I haven't done something like this before it's a guess.
You can derive an interval in seconds I believe (referencing http://nathanw.net/2012/06/30/better-date-and-time-support-in-qgis-expressions-and-styles/) from the point data - I'm assuming you have date and time (or at least time).
You could connect the points with a line (that would give you distance).
I'm thinking this might be better accomplished in a database as opposed to a shapefile (assuming shapefile).
...and I think I've just given you the most abstract assumed non-answer ever.
Lemme think on this one a bit more. Hopefully someone has a practical answer.
Randy
On 08/17/2014 05:57 PM, dean.walker151 at gmail.com wrote:
Hi all,
I’m working on some point data that has been collected using a combine in an agricultural field. Trying to figure out a way to compare speed between the dropped points? I’m not sure how to start….can anyone help?
Thanks
Dean
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140817/c5b40dbc/attachment.html>
