[Qgis-user] Velocity Difference Calculation?
Randal Hale rjhale at northrivergeographic.com
Sun Aug 17 15:42:59 PDT 2014
The part of me that screams deadline thinks maybe you toss it into
excel/calc and derive time then join that info back the distance
portion. The minute I finished that sentence that might work for a few
lines/distance - but you might have more than a few points/lines in the
problem.
To quote a person I once knew "That's a thinker".
On 08/17/2014 06:34 PM, dean.walker151 at gmail.com wrote:
> Yeah, I’ve got a distance reference that covers the amount of distance
> covered in the time from the last point.  I’m just missing the way to
> actually do the calculation in the program.  I cant see a way to
> compare a point to the one before it.
> Thanks!
> Dean
> Sent from Windows Mail
> *From:* Randal Hale <mailto:rjhale at northrivergeographic.com>
> *Sent:* ‎Sunday‎, ‎August‎ ‎17‎, ‎2014 ‎3‎:‎22‎ ‎PM
> *To:* dean.walker151 at gmail.com <mailto:dean.walker151 at gmail.com>,
> qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> I can think of a couple of ways you might be able to do this - but
> considering I haven't done something like this before it's a guess.
> You can derive an interval in seconds I believe (referencing
> http://nathanw.net/2012/06/30/better-date-and-time-support-in-qgis-expressions-and-styles/)
> from the point data  - I'm assuming you have date and time (or at
> least time).
> You could connect the points with a line (that would give you distance).
> I'm thinking this might be better accomplished in a database as
> opposed to a shapefile (assuming shapefile).
> ...and I think I've just given you the most abstract assumed
> non-answer ever.
> Lemme think on this one a bit more. Hopefully someone has a practical
> answer.
> Randy
> On 08/17/2014 05:57 PM, dean.walker151 at gmail.com wrote:
>     Hi all,
>     I’m working on some point data that has been collected using a
>     combine in an agricultural field. Trying to figure out a way to
>     compare speed between the dropped points?  I’m not sure how to
>     start….can anyone help?
>     Thanks
>     Dean
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140817/a1edd52e/attachment.html>
