[Qgis-user] Velocity Difference Calculation?
Damien Stephens
Damien.Stephens at sandfire.com.au
Sun Aug 17 17:25:24 PDT 2014
Very clunky, but if you have a consecutive numerical field in your table, you could add a new field which equals old field -1, then bring the table in twice and link by old field to new field. The rest should be easy.
Probably much easier in a database though.
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Randal Hale
Sent: Monday, 18 August 2014 6:43 AM
To: dean.walker151 at gmail.com; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Velocity Difference Calculation?
The part of me that screams deadline thinks maybe you toss it into excel/calc and derive time then join that info back the distance portion. The minute I finished that sentence that might work for a few lines/distance - but you might have more than a few points/lines in the problem.
To quote a person I once knew "That's a thinker".
On 08/17/2014 06:34 PM, dean.walker151 at gmail.com<mailto:dean.walker151 at gmail.com> wrote:
Yeah, I’ve got a distance reference that covers the amount of distance covered in the time from the last point. I’m just missing the way to actually do the calculation in the program. I cant see a way to compare a point to the one before it.
Thanks!
Dean
Sent from Windows Mail
From: Randal Hale<mailto:rjhale at northrivergeographic.com>
Sent: Sunday, August 17, 2014 3:22 PM
To: dean.walker151 at gmail.com<mailto:dean.walker151 at gmail.com>, qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
I can think of a couple of ways you might be able to do this - but considering I haven't done something like this before it's a guess.
You can derive an interval in seconds I believe (referencing http://nathanw.net/2012/06/30/better-date-and-time-support-in-qgis-expressions-and-styles/) from the point data - I'm assuming you have date and time (or at least time).
You could connect the points with a line (that would give you distance).
I'm thinking this might be better accomplished in a database as opposed to a shapefile (assuming shapefile).
...and I think I've just given you the most abstract assumed non-answer ever.
Lemme think on this one a bit more. Hopefully someone has a practical answer.
Randy
On 08/17/2014 05:57 PM, dean.walker151 at gmail.com<mailto:dean.walker151 at gmail.com> wrote:
Hi all,
I’m working on some point data that has been collected using a combine in an agricultural field. Trying to figure out a way to compare speed between the dropped points? I’m not sure how to start….can anyone help?
Thanks
Dean
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140818/aff9f9c9/attachment.html>
