[Qgis-user] Intended work-flow for joining table to layer?
    Bernd Vogelgesang
    bernd.vogelgesang at gmx.de
    Tue Aug 19 02:44:50 PDT 2014
since some versions, the once  "trivial" task to join tabular data to a
layer became very annoying and time consuming.
We have a normal point shape and an excel file which we want to join.
Export xls to csv, import through the wizard, no deal.
But using the joins from the properties is changing the field names by
adding the table name in front of the original field name.
This may be intended to prohibit confusion with the origin of the field,
but its causing a lot of work, cause even if you keep your table name as
short as it can be to be still meaningful, the combination with my still
short field names plus the table name completely destroys the field name
when saved as shape again.
table name  = join
field names: FIELDA, FIELDB, FIELDC etc
Result after save:
join_FIELD, join_FIE_1, join_FIE_2
Even with such short names, all information is destroyed, so we have to go
to the table manager (which a lot new user will not know for sure!) and
rewrite the field names completely. For 20+ fields that's no fun at all.
The second alternative to join data is through the processing toolbox
"Join attribute table".
This works great for combining to layers without that field name
hokuspokus, but at least in V2.0 on Windows (my collegues computer is not
updated yet), you can only select layers, tables can't be selected, so you
can't join them.
I had the very same issue on another dataset with 2000 items some days ago
(on Win7, V2.4): The "normal" join took ages and produced unreadable field
names, the Toolbox join didn't work, so in the end I fiddled myself into
Spatialite to be able to join those darn data sets.
I will stick to the Spatialite approach, but for my collegues, this is
completely beyond the scope.
Can anyone share their work-flows for joining data which is doable by
normal dudes too?
Cheers
Bernd
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
