[Qgis-user] Intended work-flow for joining table to layer?
Carlos Cerdán sig.upagu at gmail.com
Tue Aug 19 06:04:14 PDT 2014
Hi Bernd
In this case, After charging in QGIS, I change the name of second table
to... nothing (yes, you can have charged a table without name), so the
field name resulting is "_filed1", "_field2", etc.
Attribute tables are DBF tables, and DBF fields are max 10 characters
length, so before union, names must be 9 character lenght.
Regards
Carlos Cerdán
2014-08-19 4:44 GMT-05:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
> Hi,
> since some versions, the once  "trivial" task to join tabular data to a
> layer became very annoying and time consuming.
> We have a normal point shape and an excel file which we want to join.
> Export xls to csv, import through the wizard, no deal.
> But using the joins from the properties is changing the field names by
> adding the table name in front of the original field name.
> This may be intended to prohibit confusion with the origin of the field,
> but its causing a lot of work, cause even if you keep your table name as
> short as it can be to be still meaningful, the combination with my still
> short field names plus the table name completely destroys the field name
> when saved as shape again.
> table name  = join
> field names: FIELDA, FIELDB, FIELDC etc
> Result after save:
> join_FIELD, join_FIE_1, join_FIE_2
> Even with such short names, all information is destroyed, so we have to go
> to the table manager (which a lot new user will not know for sure!) and
> rewrite the field names completely. For 20+ fields that's no fun at all.
> The second alternative to join data is through the processing toolbox
> "Join attribute table".
> This works great for combining to layers without that field name
> hokuspokus, but at least in V2.0 on Windows (my collegues computer is not
> updated yet), you can only select layers, tables can't be selected, so you
> can't join them.
> I had the very same issue on another dataset with 2000 items some days ago
> (on Win7, V2.4): The "normal" join took ages and produced unreadable field
> names, the Toolbox join didn't work, so in the end I fiddled myself into
> Spatialite to be able to join those darn data sets.
> I will stick to the Spatialite approach, but for my collegues, this is
> completely beyond the scope.
> Can anyone share their work-flows for joining data which is doable by
> normal dudes too?
> Cheers
> Bernd
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140819/38d2cc37/attachment.html>
