[Qgis-user] Intended work-flow for joining table to layer?
Alexander Bruy
alexander.bruy at gmail.com
Wed Aug 20 04:27:00 PDT 2014
Hi Bernd,
2014-08-20 12:02 GMT+03:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
> what format other than the standard shp format could be proposed then for
> e.g. for the Processing output (GRASS and SAGA functions seem not to support
> memory layer)?
Any GDAL-supported format. E.g. SQLite, GML, KML, DXF, GeoJSON etc.
> And it does not seem to be possible to change the default save option from
> shp to sth else permanently for the toolbox?
Right, currently there is no way to set default output format. But
this can be added
I think.
> The charm of Processing is that you can quickly do a lot of
> trial-and-error-runs on datasets without having to care where the data ends
> up cause its temporary anyway.
Hmm, for trial-and-error-runs shapefile IMO is ok. As I understand the problem
is not in Processing algs, but in join functionality from core.
Alexander Bruy
