[Qgis-user] Intended work-flow for joining table to layer?
Andreas Neumann
a.neumann at carto.net
Wed Aug 20 04:32:42 PDT 2014
It would be really nice if SpatiaLite could be the default format in
Processing.
But I remember that Victor once said that ESRI Shape is the only vector
format that properly works with SAGA GIS. Not sure if this is still the
case or not.
Andreas
Am 20.08.2014 11:27, schrieb Alexander Bruy:
> Hi Bernd,
> 2014-08-20 12:02 GMT+03:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
>> what format other than the standard shp format could be proposed then for
>> e.g. for the Processing output (GRASS and SAGA functions seem not to support
>> memory layer)?
> Any GDAL-supported format. E.g. SQLite, GML, KML, DXF, GeoJSON etc.
>> And it does not seem to be possible to change the default save option from
>> shp to sth else permanently for the toolbox?
> Right, currently there is no way to set default output format. But
> this can be added
> I think.
>> The charm of Processing is that you can quickly do a lot of
>> trial-and-error-runs on datasets without having to care where the data ends
>> up cause its temporary anyway.
> Hmm, for trial-and-error-runs shapefile IMO is ok. As I understand the problem
> is not in Processing algs, but in join functionality from core.
