[Qgis-user] qgis-server and oracle data
Andreas Neumann
a.neumann at carto.net
Thu Aug 21 12:52:46 PDT 2014
Please see this other thread over at qgis-server - a similar topic was
just discussed recently:
http://lists.osgeo.org/pipermail/qgis-developer/2014-August/034195.html
Hope this also helps for you. It is probably an issue with the Oracle
library.
Even if you are in Win7 ( is your server really on Win7 - how can you
run a server on Win 7 ? ) - I still assume that you are missing the
Oracle driver or it can't be found be QGIS server.
Andreas
Am 21.08.2014 14:39, schrieb Toni Pignataro:
> hi to all,
> i'm displaying data from an oracle database and shape data in qgis and
> it works fine. but publishing the project and displaying it through my
> qgis-server in qgis does not work.
> loading the qgis-server wms into qgis desktop, it only shows the
> shape-data layer and not the oracle data.
> also the capabilities document is only showing the name of the shape
> layer and not oracle data layer.
> my system information:
> * Win7
> * qgis 2.01
> * qgis-server installation based on this instruction [1]
> has anyone an idea or suggestion?
> thanks in advance and best regards,
> toni
> [1] http://anitagraser.com/2012/04/06/qgis-server-on-windows7-step-by-step/
> Qgis-user mailing list
