[Qgis-user] qgis-server and oracle data
    Toni Pignataro
    toni.pignataro at wheregroup.com
    Fri Aug 22 00:54:05 PDT 2014
hi andreas and thanks for the link and suggestion, i 'll try it out.
win 7 (64bit) is only for testing surpose and the final system is
windows server 2012.
regards,
toni
Am 21.08.2014 21:52, schrieb Andreas Neumann:
> Hi,
> Please see this other thread over at qgis-server - a similar topic was
> just discussed recently:
> http://lists.osgeo.org/pipermail/qgis-developer/2014-August/034195.html
> Hope this also helps for you. It is probably an issue with the Oracle
> library.
> Even if you are in Win7 ( is your server really on Win7 - how can you
> run a server on Win 7 ? ) - I still assume that you are missing the
> Oracle driver or it can't be found be QGIS server.
> Andreas
> Am 21.08.2014 14:39, schrieb Toni Pignataro:
>> hi to all,
>> i'm displaying data from an oracle database and shape data in qgis and
>> it works fine. but publishing the project and displaying it through my
>> qgis-server in qgis does not work.
>> loading the qgis-server wms into qgis desktop, it only shows the
>> shape-data layer and not the oracle data.
>> also  the capabilities document is only showing the name of the shape
>> layer and not oracle data layer.
>> my system information:
>> * Win7
>> * qgis 2.01
>> * qgis-server installation based on this instruction [1]
>> has anyone an idea or suggestion?
>> thanks in advance and best regards,
>> toni
>> [1] http://anitagraser.com/2012/04/06/qgis-server-on-windows7-step-by-step/
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Toni Pignataro
B.- Sc. Cartography and Geomatics
- Anwendungsentwickler und Projektmanager -
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 20
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
