[Qgis-user] Running EPANET from QGIS
Vincent Picavet
vincent.ml at oslandia.com
Fri Aug 22 08:56:36 PDT 2014
Hello,
Le vendredi 22 août 2014 17:42:03, Francesco Liva a écrit :
> I am using QGIS 2.4. Have added GHYDRAULICS plugin, have added Epanet
> Drinking water flow simulation, within Processing.
Do you use Ghydraulics, or qgis-epanet Processing integration ?
These two are separate products.
QGIS Epanet Processing plugin is the following one :
http://www.oslandia.com/qgis-plugin-for-water-management-en.html
There is a first step with epanet tutorial, but only in french for the moment,
sorry :
http://www.oslandia.com/premiers-pas-avec-qgis-epanet.html
You can probably get a translation with google which will be enough to begin
with, before we translate it into english.
Before going further, you have to detial which is the plugin you are using.
Vincent
> I have added a table TIMES and REPORT as:
> "simulation title", duration, "hydraulic timestep", "quality timestep",
> "pattern timestep", "pattern start", "report timestep", "report start",
> "start clocktime", statistic
> Epanet Simulation, 48:00, 0:05, 0:05, 0:05, 0:00, 0:05, 0:00, 12:00 AM,
> None
> And
> "simulation title", "status", "summary", "nodes", "links"
> Epanet Simulation, Full, No, ALL, ALL
> When I run the: Epanet Drinking water flow simulation, within Processing I
> get the message:
> Algorithm Simulate flow in drinking water network starting...
> No simulation named 'Epanet Simulation' in TIMES
> I am not an expert, have surely forget something or made an error. Can
> anybody help me?
> Best Regards
> Francesco Liva
> ______________________________
> 27, Triq Ix-Xatt, Kalkara, Malta
> ☎ +356 99 38 01 68 mobile
> ☎ +356 27 32 76 78 home
