[Qgis-user] Running EPANET from QGIS
    Francesco Liva
    fr.liva at gmail.com
    Fri Aug 22 09:33:07 PDT 2014
Hello
Thakyou for yoiur answer.
The PLUGINS I have added are:
GHYDRAULICS
and
QGIS_EPANET
plus many other plugins, not related to EPANET.
The message I get was while using QGIS_EPANET, in Processing, Simulate flow in drinking ....
Best Regards
Francesco Liva
______________________________
27, Triq Ix-Xatt, Kalkara, Malta
☎ +356 99 38 01 68 mobile
☎ +356 27 32 76 78 home
Via Tevere 13-A, 00198 Rome
☎ +39 06 841 32 64 home
☎ +39 333 750 99 83 mobile
30, Rue V. Contesso, Villefranche/S/M
☎ +33 (0) 4 93 80 67 21
Tsintsadze Str.
Tbilisi  Georgia
+995 577 17 70 81
Fr.Liva at gmail.com
☏ Francesco.Liva
On 22 Aug 2014, at 17:56, Vincent Picavet <vincent.ml at oslandia.com> wrote:
> Hello,
> Le vendredi 22 août 2014 17:42:03, Francesco Liva a écrit :
>> I am using QGIS 2.4. Have added GHYDRAULICS plugin, have added Epanet
>> Drinking water flow simulation, within Processing.
> Do you use Ghydraulics, or qgis-epanet Processing integration ?
> These two are separate products.
> QGIS Epanet Processing plugin is the following one :
> http://www.oslandia.com/qgis-plugin-for-water-management-en.html
> There is a first step with epanet tutorial, but only in french for the moment,
> sorry :
> http://www.oslandia.com/premiers-pas-avec-qgis-epanet.html
> You can probably get a translation with google which will be enough to begin
> with, before we translate it into english.
> Before going further, you have to detial which is the plugin you are using.
> Vincent
>> I have added a table TIMES and REPORT as:
>> "simulation title", duration, "hydraulic timestep", "quality timestep",
>> "pattern timestep", "pattern start", "report timestep", "report start",
>> "start clocktime", statistic
>> Epanet Simulation, 48:00, 0:05, 0:05, 0:05, 0:00, 0:05, 0:00, 12:00 AM,
>> None
>> And
>> "simulation title",  "status", "summary", "nodes", "links"
>> Epanet Simulation, Full,   No,      ALL,   ALL
>> When I run the: Epanet Drinking water flow simulation, within Processing I
>> get the message:
>> Algorithm Simulate flow in drinking water network starting...
>> No simulation named 'Epanet Simulation' in TIMES
>> I am not an expert, have surely forget something or made an error. Can
>> anybody help me?
>> Best Regards
>> Francesco Liva
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140822/dd0fb977/attachment.html>
