[Qgis-user] Fwd: Running EPANET from QGIS
Francesco Liva
fr.liva at gmail.com
Sun Aug 24 00:31:27 PDT 2014
Hello
About my problem, I forget to say something very important, but did not mention as I was considering it done. But it is not solved.
I am working with MAC and EPANET is installed with WINE version 1.7.16. That is using a C drive. It is difficult to give to QGIS the right path for the execution of the EPANET application. If I give the following path: /Applications/EPANET2.00.12.app. It does not work.
Can I still use it on a MAC?
Thankyou
Best Regards
Francesco Liva
______________________________
27, Triq Ix-Xatt, Kalkara, Malta
☎ +356 99 38 01 68 mobile
☎ +356 27 32 76 78 home
Via Tevere 13-A, 00198 Rome
☎ +39 06 841 32 64 home
☎ +39 333 750 99 83 mobile
30, Rue V. Contesso, Villefranche/S/M
☎ +33 (0) 4 93 80 67 21
Tsintsadze Str.
Tbilisi Georgia
+995 577 17 70 81
Fr.Liva at gmail.com
☏ Francesco.Liva
Begin forwarded message:
> From: Francesco Liva <Fr.Liva at gmail.com>
> Subject: Re: [Qgis-user] Running EPANET from QGIS
> Date: 22 August 2014 18:33:07 GMT+2
> To: vincent.ml at oslandia.com
> Cc: qgis-user at lists.osgeo.org
> Hello
> Thakyou for yoiur answer.
> The PLUGINS I have added are:
> GHYDRAULICS
> and
> QGIS_EPANET
> plus many other plugins, not related to EPANET.
> The message I get was while using QGIS_EPANET, in Processing, Simulate flow in drinking ....
> Best Regards
> Francesco Liva
> Tsintsadze Str.
> Tbilisi Georgia
> +995 577 17 70 81
> ☏ Francesco.Liva
> On 22 Aug 2014, at 17:56, Vincent Picavet <vincent.ml at oslandia.com> wrote:
>> Hello,
>> Le vendredi 22 août 2014 17:42:03, Francesco Liva a écrit :
>>> I am using QGIS 2.4. Have added GHYDRAULICS plugin, have added Epanet
>>> Drinking water flow simulation, within Processing.
>> Do you use Ghydraulics, or qgis-epanet Processing integration ?
>> These two are separate products.
>> QGIS Epanet Processing plugin is the following one :
>> http://www.oslandia.com/qgis-plugin-for-water-management-en.html
>> There is a first step with epanet tutorial, but only in french for the moment,
>> sorry :
>> http://www.oslandia.com/premiers-pas-avec-qgis-epanet.html
>> You can probably get a translation with google which will be enough to begin
>> with, before we translate it into english.
>> Before going further, you have to detial which is the plugin you are using.
>> Vincent
>>> I have added a table TIMES and REPORT as:
>>> "simulation title", duration, "hydraulic timestep", "quality timestep",
>>> "pattern timestep", "pattern start", "report timestep", "report start",
>>> "start clocktime", statistic
>>> Epanet Simulation, 48:00, 0:05, 0:05, 0:05, 0:00, 0:05, 0:00, 12:00 AM,
>>> None
>>> And
>>> "simulation title", "status", "summary", "nodes", "links"
>>> Epanet Simulation, Full, No, ALL, ALL
>>> When I run the: Epanet Drinking water flow simulation, within Processing I
>>> get the message:
>>> Algorithm Simulate flow in drinking water network starting...
>>> No simulation named 'Epanet Simulation' in TIMES
>>> I am not an expert, have surely forget something or made an error. Can
>>> anybody help me?
>>> Best Regards
>>> Francesco Liva
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140824/1ca0d214/attachment.html>
