[Qgis-user] geometry attribute units
    john polo
    jpolo at mail.usf.edu
    Fri Aug 22 14:27:34 PDT 2014
I have a polygon that I am trying to measure the perimeter for. I used
the Export/Add geometry columns function and a column was thus added.
The value in the column has a value that I don't understand, mostly
because I don't know what unit it used for the calculation. The
perimeter would probably be between .7 and 1 mile or the equivalent in
metric. The value given in the column is 0.0133.
How do I tell what the unit is supposed to be for these calculations?
(And how would I set/change it?) I've looked in Settings>Options on the
main QGIS window and the layer and haven't found anything. I did find
where one sets the units for the measure tool and that is set to meters,
but I am assuming the units selected for the measure tool aren't
necessarily the same as for the calculation for the geometry.
John
