[Qgis-user] Field calculator QGIS2.4 division error
ralfwessels gis at ralf-wessels.de
Fri Aug 22 09:46:31 PDT 2014
Hi Ivan,
what type of data (integer, real, string) are HC01_VC04 or HC01_VC03 and
what type od data you defined for the new column you want to create?
If the new column is real, try to use 100.0 (with decimal) instead of 100.
ralf
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Field-calculator-QGIS2-4-division-error-tp5157715p5157871.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
