[Qgis-user] Field calculator QGIS2.4 division error
    Ivan Santiago
    isantiago at ogp.pr.gov
    Fri Aug 22 13:04:58 PDT 2014
Hello all:
Thanks Ralf.
The columns used are integer. The resulting column is real, lenght=10 precision=1
Writing "HC01_VC04"  /  "HC01_VC03" * 100.0
Does not work either.
Applying convert function toreal() to one of the columns, produces correct results. I checked it against LibreOffice Calc.
BTW:
The calculator has a strange behavior though. I need to sort and sort again the calculated column to 'refresh' the table values.
QGIS 2.4 32bit under WIN7.
Iván Santiago
GIS Specialist
Information Technologies
Office of Management and Budget
787.725.9420 x 2378
Calle Cruz 254
PO Box 9023228
San Juan, PR 00902-3228
http://gis.pr.gov<http://gis.pr.gov/>
Sent: Thursday, August 21, 2014 4:04 PM
To: 'qgis-user at lists.osgeo.org'
Subject: RE: Field calculator QGIS2.4 division error
Hello all:
Does anyone have had problems with field calculations using the division operator?
I've tried many times to update a new field using both the old field calculator and the new interface but they just don't work with division.
Simple operations like:
Do not work.
The  only workaround I found was to put the function abs into the denominator:
"HC01_VC04"  /  abs("HC01_VC03") * 100
Then it gives the result but this should be avoidable.
I'll send the table used if anyone want to try it.
Qgis version is 2.4 (32bit) under WIN7.
Iván Santiago
GIS Specialist
787.725.9420 x 2378
Calle Cruz 254
PO Box 9023228
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140822/4155dd6b/attachment.html>
