[Qgis-user] QGIS_EPANET - command line tool
Larry Shaffer
larrys at dakotacarto.com
Mon Aug 25 20:11:43 PDT 2014
Hi Francesco,
To call a wine-based Windows app, with arguments from the command line,
consult the wine man page [0].
However, I am not certain this will work as a configuration value, because
the program itself needs to be prefaced with the 'wine' executable as the
caller, e.g.:
wine win_app args
whereas, the QGIS_EPANET plugin may expecting the "Epanet command line
tool" value to be explicitly a single file path. In other words, either the
plugin will need to be adapted to handle wine calls and output, or you can
write a wrapper script.
I recommend trying to craft a wrapper shell script that acts as a proxy to
calling wine and passing on any arguments to the wine-based app, then a
single file path to the wrapper script will probably satisfy the plugin's
configuration.
No guarantee on any of this, or whether the wine-based app's output will be
readable to the plugin. :-)
There is also an older post that may be of interest on using Homebrew's
wine installation and where the Windows programs/files are located in your
Home folder [1].
Alternatively, and if you have a Windows OS license, you can use a wrapper
script for calling a program from within a running instance of a virtual
machine, e.g. VirtualBox via 'VBoxManage guestcontrol' [2].
[0] https://www.winehq.org/docs/wine
[1] http://www.davidbaumgold.com/tutorials/wine-mac/
[2] http://www.virtualbox.org/manual/ch08.html#vboxmanage-guestcontrol
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Sun, Aug 24, 2014 at 3:09 AM, Francesco Liva <fr.liva at gmail.com> wrote:
> Hello
> I have a MAC computer, running QGIS. Have installed EPANET with WINE
> 1.7.16.
> I have installed the experimental plugins: QGIS_EPANET.
> Does anybody knows how to use the EPANET (Drinking water flow simulation)
> and how to define the "Epanet command line tool" under the PROCESSING
> OPTIONS.
> Thank you
> Best Regards
> Francesco Liva
> ______________________________
> 27, Triq Ix-Xatt, Kalkara, Malta
> ☎ +356 99 38 01 68 mobile
> ☎ +356 27 32 76 78 home
> Via Tevere 13-A, 00198 Rome
> ☎ +39 06 841 32 64 home
> ☎ +39 333 750 99 83 mobile
> 30, Rue V. Contesso, Villefranche/S/M
> ☎ +33 (0) 4 93 80 67 21
> Tsintsadze Str.
> Tbilisi Georgia
> +995 577 17 70 81
> Fr.Liva at gmail.com
> ☏ Francesco.Liva
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140825/efc88325/attachment.html>
