[Qgis-user] QGIS_EPANET - command line tool
Francesco Liva
fr.liva at gmail.com
Tue Aug 26 03:16:15 PDT 2014
Hi Larry
Thank you for your answer, I have made an AppleScript with the following:
tell application "Terminal"
do script "open /Applications/EPANET2.00.12.app"
end tell
and I have tried as well to give to PROCESSING within QGIS the following path:
In both cases I get the following error message:
Algorithm Simulate flow in drinking water network starting...
running simulation
[Errno 13] Permission denied See log for more details
Which is the PERMISSION, does it depends from WINE permission?
Sorry I am not an expert.
Thank you
Best Regards
Francesco Liva
______________________________
27, Triq Ix-Xatt, Kalkara, Malta
☎ +356 99 38 01 68 mobile
☎ +356 27 32 76 78 home
Via Tevere 13-A, 00198 Rome
☎ +39 06 841 32 64 home
☎ +39 333 750 99 83 mobile
30, Rue V. Contesso, Villefranche/S/M
☎ +33 (0) 4 93 80 67 21
Tsintsadze Str.
Tbilisi Georgia
+995 577 17 70 81
Fr.Liva at gmail.com
☏ Francesco.Liva
On 26 Aug 2014, at 05:11, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi Francesco,
> To call a wine-based Windows app, with arguments from the command line, consult the wine man page [0].
> However, I am not certain this will work as a configuration value, because the program itself needs to be prefaced with the 'wine' executable as the caller, e.g.:
> wine win_app args
> whereas, the QGIS_EPANET plugin may expecting the "Epanet command line tool" value to be explicitly a single file path. In other words, either the plugin will need to be adapted to handle wine calls and output, or you can write a wrapper script.
> I recommend trying to craft a wrapper shell script that acts as a proxy to calling wine and passing on any arguments to the wine-based app, then a single file path to the wrapper script will probably satisfy the plugin's configuration.
> No guarantee on any of this, or whether the wine-based app's output will be readable to the plugin. :-)
> There is also an older post that may be of interest on using Homebrew's wine installation and where the Windows programs/files are located in your Home folder [1].
> Alternatively, and if you have a Windows OS license, you can use a wrapper script for calling a program from within a running instance of a virtual machine, e.g. VirtualBox via 'VBoxManage guestcontrol' [2].
> [0] https://www.winehq.org/docs/wine
> [1] http://www.davidbaumgold.com/tutorials/wine-mac/
> [2] http://www.virtualbox.org/manual/ch08.html#vboxmanage-guestcontrol
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> On Sun, Aug 24, 2014 at 3:09 AM, Francesco Liva <fr.liva at gmail.com> wrote:
> Hello
> I have a MAC computer, running QGIS. Have installed EPANET with WINE 1.7.16.
> I have installed the experimental plugins: QGIS_EPANET.
> Does anybody knows how to use the EPANET (Drinking water flow simulation) and how to define the "Epanet command line tool" under the PROCESSING OPTIONS.
> Thank you
> Best Regards
> Francesco Liva
> Tsintsadze Str.
> Tbilisi Georgia
> +995 577 17 70 81
> ☏ Francesco.Liva
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140826/24adb5e9/attachment.html>
