[Qgis-user] QGIS BROWSER uselessness!
Filipe Dias filipesdias at gmail.com
Tue Aug 26 09:20:53 PDT 2014
The QGIS browser that's available inside QGIS is quite useful and for the
most part it works as well as ArcCatalog. The only issue I have is that
it's not possible to rename or delete layers with it (I think I submitted a
feature request a about this 2 years ago).
As for the standalone Qgis browser, I've never found any use for it. In the
past I used ArcCatalog as a file manager for deleting and renaming
shapefiles and rasters, but that was about it.
On Tue, Aug 26, 2014 at 4:20 PM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> On Tue, Aug 26, 2014 at 3:09 PM, SIT delle Riserve Naturali di Legambiente
> Sicilia <sit at legambienteriserve.it> wrote:
>> Can someone explain the usefulness of QGIS BROWSER?
>> It 's very slow, does not allow you to rename files, and does not allow
>> drag and drop files in QGIS DESKTOP!
> 1. I don't find it to be slow in my computer. In fact I have tested to
> open the same folder full of shapefiles both in QGIS browser and Arccatalog
> 9.3, and I can second Paolo experience. ArcCatalog hangs a bit before
> showing the files and previewing, while QGIS Browser seems instant;
> 2. You are right, it does not allow one to rename files;
> 2. It DOES allow drag and drop to the QGIS Desktop (I have just tested).
>> I think it would be very useful if it worked as ArcCatalog!
> Would the "Legambiente Comitato Regionale Siciliano" consider sponsoring
> the needed changes? Rename files seems a nice feature to have.
> Best regards,
> Alexandre Neto
>> Tata Livreri
>> Ufficio Gestione Riserve
>> Sistema Informativo Territoriale
>> tel 0916262697 - 0906264139
>> www.legambienteriserve.it
>> via Tripoli 3 - Palermo 90138
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140826/2695ddec/attachment.html>
