[Qgis-user] Geometry functions like xat(0) in "Processing"s field calculators
magerlin
MAP at ramboll.dk
Wed Aug 27 03:51:38 PDT 2014
Can anybody tell me how to make field calculations inside a Processing Model
using geometry functions?
I would like to extract the coordinates of the start and ending points of
polylines in a shapefile.
Doing it manually in the field Calculator I would use xat(0), yat(0),
xat(-1) and yat(-1).
But in field calculator in Processing you can apparently not use the
geometry functions.
I have tried the Advanced Python field calculator and got as far as knowing
I have have to write something like:
value = $geom.???
But I cannot figure out if there is something like xat(0) possible in this
syntax?
Regards Morten
Currently using Qgis 2.2 (OSGeo4),
Windows 7, 64bit
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geometry-functions-like-xat-0-in-Processing-s-field-calculators-tp5158577.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
