[Qgis-user] OpenStreetMap Error
Andre Joost
andre+joost at nurfuerspam.de
Thu Aug 28 07:44:57 PDT 2014
Am 28.08.2014 16:15, schrieb Glenn Weller:
> I have been using Qgis 1.8 for a couple of years and have decided
> that it is time to upgrade. I have installed Qgis 2.2 on my Windows 7
> laptop and I can no longer use OpenStreetMap.
By now, QGIS 2.4 is current. The Openstreetmap plugin of QGIS 1.8 did
not work lately, so it was completely refurnished. As a consequence,
older projects with OSM data will not work anymore, you have to add OSM
manually again.
> I opened a project I
> made using Qgis 1.8 and the street map layer was no longer there. I
> then opened the OpenStreetMap (Vector --> OpenStreetMap -->
> Download Data) in Qgis 2.2, left the defaults alone, and clicked on
> the "OK" button. I received the following error message:
> "Cannot open output file:"
The download area is dependent on the current canvas extent. If that was
the world, the data provider (Overpass API) will reject your request.
Try with a smaller area of interest, or use a postgis database of your
country filled with a Geofabrik extract via osm2pgsql, or use the
Openlayers plugin with an Openstreetmap background. This is always
available, independent from the size of the area of your interest.
> P.S. I also could not use OpenStreetMap with Qgis 2.4 so I
> uninstalled it and tried Qgis 2.2 with the hope that it would not be
> a problem in an older version. No such luck!
No, between 2.4 and 2.2 was no big change in the OSM plugin. The
Openlayers plugin, however, had to be changed at that point.
Greetings,
André Joost
