[Qgis-user] OpenStreetMap Error
Laura O'Grady laura at lauraogrady.ca
Thu Aug 28 11:43:51 PDT 2014
Hi Glenn,
It's not clear to me from your message whether you're still using the file you created in QGIS 1.8 or not. Please start with a fresh file, load Open Street Layers as you have already found its new menu location in 2.4 then use the OSM plug-in and let us know what happens.
You may also want to search through this list's archive as I recently posted a similar question on the use of OSM with QGIS 2.4 on Win7 64-bit.
Laura
> Message: 12
> Date: Thu, 28 Aug 2014 07:15:11 -0700
> From: Glenn Weller <glenn_d_weller at sbcglobal.net>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] OpenStreetMap Error
> Message-ID:
>    <1409235311.28691.YahooMailNeo at web181302.mail.ne1.yahoo.com>
> Content-Type: text/plain; charset="us-ascii"
> I have been using Qgis 1.8 for a couple of years and have decided that it is time to upgrade. I have installed Qgis 2.2 on my Windows 7 laptop and I can no longer use OpenStreetMap. I opened a project I made using Qgis 1.8 and the street map layer was no longer there. I then opened the OpenStreetMap (Vector --> OpenStreetMap --> Download Data) in Qgis 2.2, left the defaults alone, and clicked on the "OK" button. I received the following error message:
> "Cannot open output file:"
> I must be missing either a dependent plug-in or a dll but can find no documentation about this error.
> I use the OpenStreetmap functionality a lot and it has become a necessity for me.
> Glenn
> P.S. I also could not use OpenStreetMap with Qgis 2.4 so I uninstalled it and tried Qgis 2.2 with the hope that it would not be a problem in an older version. No such luck!
