[Qgis-user] OpenStreetMap Error
Laura O'Grady laura at lauraogrady.ca
Thu Aug 28 12:44:07 PDT 2014
Hi Glenn,
I'm away from my machine that has QGIS installed so I can't recreate the steps I used to d/l tiles. Pls take a look at the archives as I know i described it there.
I was only ever able to get it to work for an individual session - when I close the .qgs file with the OSM-related work and re-open it the OSM map tiles are not there. I have to re-load as a basemap via the Open Layers menu. I thought when I had it working in 2.2 that this was not the case. I may be wrong because it was only a few weeks between my use of 2.2 and 2.4, which was what broke the OSM plug-in for me.
Laura
On 2014-08-28, at 3:19 PM, Glenn Weller <glenn_d_weller at sbcglobal.net> wrote:
> Hi Laura,
> I tried it both ways. I started out using the original project I created using QGIS 1.8 and, of course, it didn't work. So I recreated the same project using QGIS 2.2 and I got the same error.
> After playing with plug-ins for a while I found one (TileMapScalePlugin) that would add a street layer. However it is lower resolution that I would like and the three layers to choose from (osm_bikemaps.xml, osm_landscape.xml, and osm_mapnik.xml) are really not what I was looking for.
> I also received a response from André who wondered if I was trying to map too large an area (like the entire U.S.). I am trying to obtain a Google/Yahoo map for an area in central California that I have been able to successfully map in QGIS 1.8. I doubt that the area I am trying to map is too large.
> I suppose I forgot to mention it but I am running Windows 7 32 bit.
> Thank you.
> Glenn
> From: Laura O'Grady <laura at lauraogrady.ca>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Sent: Thursday, August 28, 2014 1:43 PM
> Subject: Re: [Qgis-user] OpenStreetMap Error
> Hi Glenn,
> It's not clear to me from your message whether you're still using the file you created in QGIS 1.8 or not. Please start with a fresh file, load Open Street Layers as you have already found its new menu location in 2.4 then use the OSM plug-in and let us know what happens.
> You may also want to search through this list's archive as I recently posted a similar question on the use of OSM with QGIS 2.4 on Win7 64-bit.
> Laura
> > Message: 12
> > Date: Thu, 28 Aug 2014 07:15:11 -0700
> > From: Glenn Weller <glenn_d_weller at sbcglobal.net>
> > Subject: [Qgis-user] OpenStreetMap Error
> > Message-ID:
> >    <1409235311.28691.YahooMailNeo at web181302.mail.ne1.yahoo.com>
> > Content-Type: text/plain; charset="us-ascii"
> > I have been using Qgis 1.8 for a couple of years and have decided that it is time to upgrade. I have installed Qgis 2.2 on my Windows 7 laptop and I can no longer use OpenStreetMap. I opened a project I made using Qgis 1.8 and the street map layer was no longer there. I then opened the OpenStreetMap (Vector --> OpenStreetMap --> Download Data) in Qgis 2.2, left the defaults alone, and clicked on the "OK" button. I received the following error message:
> > "Cannot open output file:"
> > I must be missing either a dependent plug-in or a dll but can find no documentation about this error.
> > I use the OpenStreetmap functionality a lot and it has become a necessity for me.
> > Glenn
> > P.S. I also could not use OpenStreetMap with Qgis 2.4 so I uninstalled it and tried Qgis 2.2 with the hope that it would not be a problem in an older version. No such luck!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140828/9b8fed69/attachment.html>
