[Qgis-user] ogr2ogr, osm, and spatialite
Even Rouault
even.rouault at spatialys.com
Sun Aug 31 12:53:50 PDT 2014
Le dimanche 31 août 2014 21:50:31, Jukka Rahkonen a écrit :
> Thomas Endres <endres.thomas at ...> writes:
> > I have downloaded north-america-latest.osm.pbf from geofabrik and am
> struggling trying set this up for use in QGIS.
> > My hope is to create a spatialite db but I receive the following error
> repeated over a dozen times using the following command:
> > ogr2ogr -f SQLite -dsco spatialite=yes -gt 20000 --config
> OGR_SQLITESYNCRONOUS OFF north-america.sqlite north-america-latest.osm.pbf
> > Warning 1: organizePolygons() received an unexpected geometry.
> > Either a polygon with interior rings, or a polygon with less than 4
> points, or a non-Polygon geometry. Return arguments as a collection.
> > My search for a fix has proven fruitless after having the same outcome
> from a few attempts.
> > I am left with a 33.1GB file which Spatialite GUI can see but everything
> hangs when trying to do anything with GIS.
> Hi,
> Add -skipfailures to your command and have a new try. If that does not work
> try to do import layer by layer and add -sql "select * from multipolygons
> where IsValid(geometry)=1".
Actually, this warning is just a warning, and not a critical error that will
stop conversion. When this occurs, the way/relation will be skipped. Due to
the way the OSM database is done, it is possible to have non-valid polygons,
and indeed there are such polygons.
So you can safely ignore those warnings about organizePolygons()
> -Jukka Rahkonen-
> Qgis-user mailing list
http://www.spatialys.com
