[Qgis-user] Errorreport while starting QGIS (2.2 and 2.4) after customization UI
Julian Schall
j.schall at ff-forst.de
Tue Jul 1 09:37:44 PDT 2014
Hi all,
I installed QGIS 2.2 with 32bit standalone-installer on a Windows XP Laptop.
After starting QGIS I loaded my customization.ini-file and started QGIS
again. Then a error occurs, that tells me: Crash displayed - Minidump in
c:\documents\admin\...\Temp\qgis-20140630-161131-3332-452-8fddd08a.dmp
written.
At the bottom of the QGIS Valmiera-Window is written: Re-establishing of the
window-status.
Both is translatet from german into english, so maybe in english version the
formulations of the error-reports are a bit differing.
I'm not sure, if the problem is the .ini-file, but could be. I built it with
2.2 and on other PCs it works fine.
I deinstalled QGIS many times, erased all connected files and installed it
again, but always the same error while starting process (screenshot of the
error is attached or under
https://www.dropbox.com/s/47q7e94fvyrpmyj/Fehlermeldung.JPG.
I tried installation of 2.2 and 2.4, with standalone and with
OSGeo4W-Installer, nothing works.
Googling of the error doesn't provide any solution.
Can anybody help to get QGIS to work on that computer again?
Thank you!
Julian
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140701/cdaf1783/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140701/cdaf1783/attachment.jpe>
