[Qgis-user] Errorreport while starting QGIS (2.2 and 2.4) after customization UI
Gino Pirelli
luipir at gmail.com
Tue Jul 1 23:29:43 PDT 2014
whould be usefule to file a tiket with dmp file and your customization ini
file o reproduce the error and to solve
this coul dbe and argument for qgis-developer mailing list
regards,
Luigi Pirelli (luigi.pirelli at faunalia.it - luipir at gmail.com)
On 1 July 2014 18:37, Julian Schall <j.schall at ff-forst.de> wrote:
> Hi all,
> I installed QGIS 2.2 with 32bit standalone-installer on a Windows XP
> Laptop. After starting QGIS I loaded my customization.ini-file and started
> QGIS again. Then a error occurs, that tells me: *Crash displayed –
> Minidump in
> c:\documents\admin\...\Temp\qgis-20140630-161131-3332-452-8fddd08a.dmp
> written*.
> At the bottom of the QGIS Valmiera-Window is written: Re-establishing of
> the window-status.
> Both is translatet from german into english, so maybe in english version
> the formulations of the error-reports are a bit differing.
> I’m not sure, if the problem is the .ini-file, but could be. I built it
> with 2.2 and on other PCs it works fine.
> I deinstalled QGIS many times, erased all connected files and installed it
> again, but always the same error while starting process (screenshot of the
> error is attached or under
> https://www.dropbox.com/s/47q7e94fvyrpmyj/Fehlermeldung.JPG.
> I tried installation of 2.2 and 2.4, with standalone and with
> OSGeo4W-Installer, nothing works.
> Googling of the error doesn’t provide any solution.
> Can anybody help to get QGIS to work on that computer again?
> Thank you!
> Julian
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140702/0b55260b/attachment.html>
