[Qgis-user] I can't install Taudem in Qgis 2.4.0 andd windows 8.1
Alexander Bruy
alexander.bruy at gmail.com
Tue Jul 8 08:55:06 PDT 2014
Hi Paulo,
are there any related messages in Processing History and Log
window? Are you able to get correct result when running TauDEM
tools directly from command line?
2014-07-08 17:11 GMT+03:00 Paulo Praça <pracapaulo at gmail.com>:
> When I run Pit removal i get the following message:
> Oooops! The following output layers could not be open
> Pit Removed Elevation Grid:
> C:\Users\ppraca\AppData\Local\Temp\processing\a06fa485001847daa736f9db8c7e1bef\fel.tif
> The above files could not be opened, which probably indicates that they were
> not correctly produced by the executed algorithm
> Checking the log information might help you see why those layers were not
> created as expected
> My setup is:
> MPICH2/OpenMPI bin directory= C:\ProgramFiles\MPICH2\bin
> and
> Taudem command line tools folder= C:\OSGeo4w64\apps\Taudem5Exex64
> I have installed taudem 5.0.6 version
> I someone could help me .
> Thanks for your attention,
> Paulo Praça
> Qgis-user mailing list
Alexander Bruy
